La Cimbali M32
Hi there people , i have a La cimbal Class m32 , and i have too much water coming out of the head , would anyone no how i could adjust the flow right back???
thanks
andrew
thanks
andrew
- cannonfodder
A smaller group jet will reduce the flow rate. However, proper grind, distribution and dose will yield a proper extraction flow. Some machines, adjusting with the flow rate will make the machine easier to use but it should work just fine even without a group jet.
I have an M31, which is essentially the same machine with an older electronic control system. It's difficult to know what the cause is without more information.
Could you be more specific about too much water coming out of the group? Is this when you are trying to pull a shot?
What kind of grinder are you using? Have you tried a finer grind?
Are you new to making espresso?
If given a choice between Starbucks and espresso, I'll choose espresso every time.
