by Ken Fox on Sun Apr 03, 2011 2:47 pm
Hi,
I am going to guess that the grouphead is really hot because there is not enough water flow going through it to cool it off. Cimbali groupheads do tend to overheat when left "on idle," so this is normal, and why we do "cooling flushes." Of course, your pressurestat setting might be a little high also.
There are so many different reasons why your machine could exhibit the behavior you show on the youtube video that I would hesitate to hazard a guess. I would add, however, that assuming the M32 has a rotary pump, and if the rotary pump is still functional, you risk damaging it if for some reason the problem is that water is blocked from getting to the pump itself. You do not want to run a rotary pump when it is "dry." So, it is possible that if you don't know what you are doing that you could be getting yourself in for an expensive repair by trying to fix what might be a kinked tube or other minor problem, without knowing what you are doing.
The first question you want to ask yourself is whether you have the skill, inclination, and time to try to fix this yourself. This includes such issues as whether you are cognizant of the risks that exist in working around very hot water, near sharp edges that might cut you, and in close proximity to electrical wiring that might do you serious harm. Can you trust yourself to religiously unplug your machine every time before you take off the side panels?
Many of us here are more or less self taught espresso machine mechanics, but unless you have the aptitude for mechanical things and can work with great attention to such things as not getting electrocuted, you might be better off having your machine serviced by a professional.
Good luck.
ken
What, me worry?
Alfred E. Neuman, 1955
