Update-
Able to get the machine hooked up to power and plumbed in.
Here is what I know - very limited electronics background (took a couple of years of it in highschool)
Cimbali Power switch is a 3 position switch. When switched all the way to the left (counterclockwise) the machine should be off (as indicated by the graphic)
However, the machine's front panel light is on. And that is the position that I put the switch in when I was testing the dosing buttons.
Once first powered on, the machine made a long beep. Nothing seemed to work, dosing buttons that is. I ended up switching the dip switches on the main board and was able to get the dosing buttons to work. But I continued to try dip switch positions (at times the machine was still powered) and now when I turn the machine on it activates both brew groups and the dosing buttons don't seem to work. I'm hoping I didn't screw something up royally when changing dip switch while powered on.
So I know the following
- Heater seems to work - water gets hotter
- Pump works - water coming out of the brew groups.
- Cup heater works - gets pretty darned hot
- Front panel lights but doesn't show any information
- The dosing pads work - well worked before I think I screwed up the main board.
- Seems that the power board works since the pump motor, heating elements and boards are getting electricity.
I'm really not sure where to begin and hope someone can offer a bit of direction.
Thanks
Mike
