by Ken Fox on Mon Mar 23, 2009 6:12 pm
Under normal circumstances, when you turn this machine on, the rotary pump will immediately come on to fill the boiler. If the rotary pump is starved for water, it will make an unpleasant noise, and after a short period of time it will burn out. If the power light is coming on, but you hear no pump noises, that would mean to me that the pump is not functioning. There are any number of reasons why the pump might not function, such as there being a problem with the pump itself, with the autofill sensor, the electrical wiring itself, or other electronics such as the brain board. It could be as simple as the wire connector coming off the autofill sensor, so a quick look inside after removing the side panels would be in order.
There is no simple water shutoff inside the machine.
Since your machine was purchased in 2005 and presumably was new at that time, this is presumably the rotary pump model.
I am not aware of the existence of a "real service manual" for this machine. If one exists, I think it is a closely guarded secret. Most commercial espresso machines are fairly modular, and the people who work on them don't generally need a manual beyond what is in the owners manual you already have.
I would suggest that you try one of the shot buttons on the top membrane panel, but since I don't know what your actual situation is as regards the pump, I don't want to suggest anything to you that might result in further damage. I suggest you call the seller and or his repair shop before you go any further.
ken
What, me worry?
Alfred E. Neuman, 1955
