chris wrote:First of all why would you do a cooling flush by opening the hot water tap??? Second if you pull water from the hot aware tap you are introducing cold wetter into your steam boiler. That will drop your pressure in your steam boiler. To do a cooling flush you need to pull water through the group not the hot water spigot.
HB wrote:Not to state the obvious, but could it be false pressure? If you open the steam valve and the pressure drops suddenly, then it's possible the vacuum breaker is sticking.
