www.ajcoffeeco.com: excellent coffee without compromise
La Cimbali Junior steam boiler not coming up to pressure... - Page 2
Postby miKe mcKoffee on Sun Nov 27, 2011 8:09 pm
chris wrote:What makes no sense is why the steam boiler pressure would drop as a result of doing a cooling flush?
Wouldn't the boiler pressure drop while doing a cooling flush or while pulling shots since bringing in cool water through the HX which then cools the boiler? Of course should only drop pressure to regular pstat toggle low point, then come back up to regular pstat toggle high point. Definitely should not have reducing or wildly varying pressure overall because of flush or shots or steaming.
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
miKe mcKoffee
Postby HB on Sun Nov 27, 2011 8:21 pm
You're in good hands with Chris' Coffee. Another possibility is scale buildup; that would explain the low brew temperature.
Postby boar_d_laze on Sat Jan 07, 2012 9:26 pm
A little follow:
This thread got derailed before really getting started because the term "cooling flush" was erroneously used. There was no cooling flush. Forget about it. There was a steam purge and/or partial boiler flush.
The problem was caused by a sticking vacuum breaker.
It can be diagnosed by letting the machine heat up, and briefly opening the steam valve. If the boiler pressure gauge drops to zero -- it's sticking in the "up" position. So, I learned from a phone call to Roger, the La Cimbali tech at Chris Coffee.
I solved the same problem with my Casa -- at least temporarily -- by opening the machine and freeing the pin on top of the vacuum breaker by pushing it in. I'm not sure if this is a temporary fix which will hold indefinitely, or I'll need to remove the old breaker and lube the pin, or replace the entire part.
My understanding is that since starting this thread Derek (aka tomesd, the OP) R and Rd the vacuum breaker in his machine which took care of his problem for awhile, but his machine is back to the same stupid trick. Derek's experience doesn't fill me with confidence, but we'll see.
BDL
boar_d_laze
Postby uscfroadie on Sat Jan 07, 2012 10:04 pm
Rich,
No need to replace the vacuum breaker as it can be broken down and the O-ring replaced. I did that on mine and had to lube the O-ring to keep it from sticking. I used Dow 111, and so far, so good.
Merle
LMWDP #273
uscfroadie
Postby boar_d_laze on Sun Jan 08, 2012 12:26 am
Good to know. Do you remember what size O ring?
BDL
boar_d_laze
Postby erics on Sun Jan 08, 2012 4:30 am
O-rings & Copper Sealing Washers
Contact me if you would like some.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby boar_d_laze on Sun Jan 08, 2012 10:15 am
Thanks Eric. Will do. So far -- after one whole day -- the "repair' is holding.
BDL
boar_d_laze
Postby boar_d_laze on Sun Jan 15, 2012 2:21 pm
A bit more follow up:
After one week following the expedient "repair" of freeing the pin, the vacuum breaker is still working as it should. So, no new o-rings, lubrication or partial rebuilds for now.
As to the rest of it... my love affair with the Casa continues.
BDL
boar_d_laze
Previous
Return to Espresso Machines
