boar_d_laze wrote:tomesd,
The issue isn't temperature stability with the DT/1, or even dialing in one preferred brew temp with it. The Junior makes a lot of things easy, those are two of them.
Rather, is varying the brew temp for one or two shots with some degree of control. As for instance, if you roast or drink a lot of different blends, and want to pull a shot of something which brews best at 2 deg F lower than your normal. The Junior isn't a PID controlled, double boiler machine like a La Spaz or La Marzocco, and that isn't something it's really designed to do. You can do it if you don't mind leaving the side panel off and screwing around with pressure (Ken's suggestion); and/or, with some fancy water-dancing (my suggestion). My way is easier but not as accurate nor reproducible.
BDL
Actually, I would never (and have never to my knowledge) suggested that -- leaving the side panel off or for that matter removing it in order to adjust the Pstat on a shot to shot basis. The machine is not designed for that. The new machines have their Pstat (a Cimbali branded microswitched pstat) in the back, which would necessitate removing BOTH side panels and the back panel, held by a minimum of 6 screws. This is beyond impractical.
The only way to do this in a practical fashion would be to replace or control the pstat through a PID, which is what I did with my machines, however not something I would recommend that others do.
For the record, I do not agree that the Cimbali Jr. design is all that temperature stable unless it is used to pull repeated shots. All it takes is a bit of time and a Scace device to prove that fact. On the plus side the Cimbali group head is a massive block of brass that is bolted directly onto the boiler, and has the HX running through it and down into the boiler. On the minus side is the fact that the group head itself is largely responsible for the actual shot temperature delivered, and it can either massively overheat if left to idle for long periods (especially if the pstat is set high to allow for rapid milk frothing), OR it can lose a lot of heat if the room in which it is located is cold.
I live in the Rockies at around 6000 feet of altitude and most houses (including mine) do not have air conditioning. During the hottest part of the summer, people tend to open up their windows when the sun goes down and to leave them open until morning, when the house is again all closed up with the hope of staying cool until the following evening when the windows will again be opened up. This results in a pretty wide temperature swing in my kitchen from (potentially) a high in the low 80's F, to a low of around 60F. My shots were coming out several degrees cooler than intended in the mornings during the summer before I figured out what was going on (heat loss from head of machine due to cold surroundings, resulting in too-cold espresso shots). A well designed double boiler machine would not have this problem. I compensated for this problem by bumping up the boiler temperature with my PID, but doing this on the stock pstat controlled machine would be a non-starter.
Granted, most people probably do not have such widely fluctuating temperatures where their espresso machines are located, and during the fall, winter, and spring, this was not a problem for me. IT does however support the notion that the Cimbali HX design is only temperature stable in certain specific situations (high volume use in a location with a stable ambient temperature). "Excessive" milk frothing will also, over time, reduce shot temps. Getting temperature stability out of this machine in low volume home use becomes easier if the pstat is set at a lower level.
I would not be satisfied with milk frothing as described for the new Casa model with the boiler temp set down in the low range as I suggested (pstat setting of 0.7 or so, as the bottom end of the deadband).
My suggestion to those who have this machine and who enjoy primarily straight shots, would be to try the lower pstat setting that I suggested for a few days to get an idea of what it would do to your shot temps and flush routines. If you find that it works better for you, then I would locate a suitable replacement steam tip that will enable you to use the machine for both straight shots and occasional milk drinks. If it doesn't work for you, then bump up the boiler temp to a level that works better for your usage pattern.
None of the above is to be interpreted to mean that I dislike this machine or I don't recommend it -- I like the Cimbali machines a lot and in fact I may buy another one for a dwelling I am considering purchasing in a city where I expect to spend more time due to business interests. The changes in design that Chris put into his Casa model are with the interests of the average user in mind. Most N. Americans make LOTS of milk drinks, and a more restricted steam tip will allow easier plus higher volume of steaming with the pstat set at the higher levels typical for N. American usage. If instead you are mostly interested in making straight shots, and having easier temperature management, this steam tip modification might conflict with getting better shot temperature stability by reducing the boiler temp. That is all.
ken
