Just received this Pub S off the truck yesterday. Scored it on the bigE last week, it has the brass panel package...
Anyhow, the machine looks really clean inside. My guess is that somebody else has gone over this machine because there is writing all over the innards as you'll see in the pics that follow. I can't tell the age either yet but the serial is 17344.
My main concerns are:
1- In picture 1, should there be a connection to the right most upper boiler fitting? It's the one dubbed "F$%K this". I'm guessing that the fitting is a water probe. I've seen in other postings that the electrical connection can be made there or at the top of the sight glass, which is where my machine is connected.
2- There is a loose wire and I'm assuming it may be for the pump. But it emanates from very low in the electrical "brain" and is from slot numbered 5. See picture 2.
3- The grouphead has a solenoid underneath it. It seems like an odd placement for that solenoid. Is this a normal placement? The group head also looks like it could be used for the older manual style heads that have the magnet donut attached.. yes? I saw that post in here somewhere.
I don't have a pump for this machine yet and I'm wondering if it's possible to install a rotary inside the frame somewhere, or should I use an external setup.
Please have a look and see what you think
Thanks
Tom
#222
