by JmanEspresso on Sun Dec 12, 2010 5:27 pm
I definitely preferred the Ridgeless Synesso baskets when I had my E-61. Both the 14gr and 18gr, IIRC. There is also a much bigger one I believe, 21grams.. but I didnt use that one.
The 14gram one worked great for doses above 16grams. I usually topped that basket out at 19grams. The 18gram basket held a few more grams, I usually only used it for doses in the 20-22gram range. If for some reason I felt like dosing in the 24-25gram range, which I personally think is a bit much, Id use the La Marzocco Triple, which is the one Chris sends with the bottomless portafilters.
My two most used baskets were the Synesso 14gram, and the standard faema 14gram. The synesso was used much more, almost all the time. The Faema 14gram was for using doses in 15-16gram range, as that was a little light for the synesso.
The Ridgeless baskets sold by Great Infusions and EspressoParts, sometimes called "La Marzocco Ridgeless" are quite similar to the ones you get direct from Synesso.
