Izzo Duetto - First time startup problem
Hello,
I just got My new Izzo Duetto and is having problems getting it to draw water from the reservoir,
The Instructions i got with the machine is not exactly the best I've seen.
I followed them as best i could.
1. lever is pointing straight down and and steam and water valve is closed, and hoses in the water tank
All power switches turned off, when i turn on main power the pump starts but no water is drawn.
Any suggestions to what i do wrong?
- EricC
Have a look here :-
http://coffeetime.wikidot.com/izzo-alex-duetto
for everything to do with the Izzo Duetto
Regards
Eric
Regards
Eric
Eric, thank you for the link.
But still can't find a solution to my problem.
When i look at the water hose i can see it pulls/sucks the water inside about 1 inch, but not further.
I believe I opened my steam valve to help purge the air when I initially hooked up mine in this same way. Also, make sure the switch behind the drip tray is set to "Reservoir" and not "Mains". Good luck - hope everything works out.
Tried that, no luck.
I'll call the dealer tomorrow.
It's working!:)
Looks like it was air in the hose blocking the water,
- jfrescki
Glad it's working. Please give us a review once you've used the machine!
Write to your Congressman. Even if he can’t read, write to him.
- Will Rogers
- Will Rogers
