I was looking at this thread because of my ECM Giotto. It is a very old one with an 18 volt transformer inside a Giemme control box. After MANY hours I was able to locate exactly what I needed. Forget about Myrra. . . They do not respond to inquiries, nor does Farnell carry the proper parts.
Mouser Electronics in Texas carries Pulse brand EI-30 transformers. EI-30 is the "style" that fits ("4 pins") the footprint on your circuit board. Phone # 1800 346 6873.
http://www.mouser.com/Mouser puts a "673" in front of the Pulse part #. But even if you enter the pulse part # it will come up in the Mouser search.
BTW the parts are at the end of their Lifecycle (End of Life: Scheduled for obsolescence and will be discontinued by the supplier.), so you may want to order 2 or 3?
In case you have to source the part yourself from Pulse Electronics. . . Follow these steps:
http://www.pulseelectronics.com/ Click on "Power" then click on "50/60Hz Encapsulated Transformers" then refine your search.
"Check" the box "EI-30" under the heading "Platform Type - 50/60Hz Xfrm".
As well as "115" (not 2x115 as this will not fit onto the circuit Board. . . too many pins) under heading "Input Voltage Range".
Where it has a field that says "Search within Box", enter "12v" and press ok.
This should show a list of 6 transformers. The only differences being the Output Voltage/Current: (VA) and the height (in mm) of each.
Pulse Part Number 030-7294-0 is a 2VA, 4 pin, 24.4mm(or .961 inch) high transformer.
Pulse Part Number 030-7330-0 is a 2.3 VA, 4 pin, 29.6mm (or 1.17 inch. Just over 1 1/8") high transformer.
Part Number 030-7330-0 may be pushing the height limit but it should fit.
If you are looking for the 18v version from Mouser, the part number is 673-030-7153-0.
I am assuming that the EI-30 is an industry standard as far as footprint and electrical connections are concerned.
