TomC wrote:I don't know if my problem is the same or not, but on my unit I noticed tonight while it was coming up to temp that there was a steady, slow drip coming from the hot water tap.
No, your issue sounds like the compression washer in the hot water valve is worn/over-compressed. I would check with your vendor or CC, but I read 10 months ago (courtesy of same OP) that the washers are not available separately, in
Izzo Duetto steam wand valve repair. Mine is at 10 months and counting, with no noticeable leakage or advancing of the shutoff point (indexed by a dot of tape at 12 o'clock on the knob). I suspect the trick to keeping these in good shape is to use the minimum torque that seals, which comes before you even feel resistance. If you crank it like your garden hose bib, it won't last. But unlike the hose bib, a 5-cent washer won't fix it.
TomC wrote:I imagine if the problem didn't go away, and I was plumbed in in the future, I'd have the risk of a big leak all over the place.
? If you plumb the drain, you have insurance, if you're only talking about the water wand drip. There's no risk of sudden, total failure; the drip will just slowly get worse.
TomC wrote:And if I leave it as is, I could run the reservoir dry.
Sure, if the drip is pretty bad. I'd be more worried about the water level in the steam boiler dropping low enough to expose the heating element, sometime
after the reservoir stops feeding the boiler. I'd start by monitoring the tank when it's not in use, say, overnight, to see how much is lost. And you can always just leave the brew boiler on and shut off the steam boiler -- it will reheat in at most 8 minutes.
