by hadriano on Tue Dec 13, 2011 11:21 am
Thanks from your response.
I have a few remarks.If you see the photo from chris with this level sensor, the probe is not bend.I believe,
depend of every boiler size, heater element, ecc, position( vertical or horizontal) the distance from sensor probe to top of the boiler is different.This is clear.This distance is possible to be adjusted how we know, not
difficult,with a little push more far inside of boiler.If mine is a limited by
bend, means the bend is not correct.Is a little philosophy, I know, BUT, here is a delicate aspect,in my
opinion.BECAUSE, how I read in coffeegeek, when you purge water, steam boiler heater ON, the pump start to refill the boiler with a delay of 14 sec.MORE.If the level of water is ok from steam, in my situation
without 0.5 liter of water( I purge this to be ok from steam), is possible when you purge water or steam, the
heater remain without water, because the pomp start with more delay.And more seconds without water from heater means quickly dead, possible not immediately but in short time.From me to make a good adjustment is nice to see the height of heater in boiler,to know the minimum level of water, to calculate the deep distance from sensor, and in final to be 100% sure in any situation the heater remain in water.But all this I believed was made by engineer of Izzo, and know I'm not very sure about this.Actual setting sacrifice the good steam from safety.STOP
ok, what temperature you use from steam boiler to dry the steam?
