by dialydose on Sun Feb 13, 2011 9:44 pm
I think Dave is correct regarding cavitation. I had a similar issue with my Vivaldi, but the facts are a little different so I won't confuse you with what I did to solve my problem. However, remember that there is a difference between pressure and flow rate. You may have sufficient pressure with insufficient flow (think of a pressure washer which can remove paint but puts out very little water). If that is the case, switching to 3/8 inch tubing often helps.
