The machine came double boxed and was packed very well. What I thought might be a quick installation took about an hour due to having to do the following:
-Unpack machine and parts
-Removing back cover and connecting the tube going to the pump
-Reassembling the back cover
-Putting on the feet
-Putting on the extra rails that I bought
-Pulling off all of the protective plastic
-Washing the drip try, water reservoir and portafilters
-Putting everything in its place such as the items listed above
-Attaching the converter cord and plugging it in
Some general observations are listed below:
-This thing is quiet. I'm used to my noisey Vibe pump but this rotary is quiet and it makes my grinder sound louder
-Steam machine!
-The feet and the optional handrails are very solid. However the handrails could have used a bigger washer or the holes could have been sized smaller for the screw
-It's heavy and has a good sized footprint, deeper than my Tea and wider too
-The panels are very nice heavy and thick. The whole thing seems a lot more solid than my Tea
-From drip tray to group head there seems to be a little less room than before and the drip tray seems more shallow
-Some how either my drip tray or the metal that is cutout of the base is off 1/8" of an inch. I thought I was crazy but I got the tape measure out and I'm not crazy
-The tube that goes into the drip tray has a rubber silicone tube on it, this prevents me from easily and quickly sliding the drip tray in and out. Need to call Chris about this as I can see this will be a pain in the future
-The cup warming tray that I put my optional handrails on the fit of that isn't as precise as I would have liked not sure why it seems to have a different contour than the shell but it fits with some wiggling
-Steaming milk will take some getting used to, the steam arm is lower and and the bends are lower thus making me hold the pitcher closer to the counter. I used to rest my arm on the portafilter for more stability
-The steam and hot water knobs are gorgeous. Much different than the other batches of Duetto's I've seen, thick, solid and heavy feeling
Overall after having it for 12 hours I like the machine. I'm a bit obsessive with fit and finish and quality of materials which makes this hard. The quality of materials are pretty good however some of the finished parts could have been better. The non-100% conforming shape of the cup warmer, the drip tray not fitting quite right, the water knob having some rough plastic edges whereas the steam does not, the slight flex when I insert a portafilter and the drip tray being off 1/8" or so takes a bit away.
Also, I purchased the bottomless portafilter. Do I have to use thinner gaskets than what the machine came shipped with? It seems that the ears may be thicker thus it sits in the group at 7 o' clock instead of 6 like the factory double and single.
