Hey guys, I was curious if anyone with the new style knobs and water tank which would be the version II I believe. It seems as mine is pretty gritty and makes noise when I turn it.
I just got my Alex last week. I had Chris' Coffee put on the joystick steam and hot water knobs, but they made the steam wand stick out a bit too much, so I just switched back to the knob for the steam wand. So far, it's seems very smooth.
Maybe you should take the valve apart and see if there's some crud in there. I believe you can order replacement internals from Chris if there's a broken spring or something that's making it gritty.
slowrey wrote:Hey guys, I was curious if anyone with the new style knobs and water tank which would be the version II I believe. It seems as mine is pretty gritty and makes noise when I turn it.
Yep take it apart, find the grit. Should be silky smooth. Maybe some machining filings or particles. The good lube is dow food safe silicone grease. Also take the wands apart and lube them. Downstream you can use the silicone to lube the e61 lever internal pistons. There are posts on how to. I do that every year or so....it makes everything sooooo smooth.
They do get some debris in them now and then. There can be metal shavings in the system from the manufacture. I have found small burrs in the works more than once. Just take it apart, clean it out and put a drop of lube on the assembly. It should smooth out.
