Izzo Alex Duetto boiler pressure safety valve - Page 2
- TomC
Im curious if this is the same issue that popped up in my Duetto's steam boiler two days ago.
There was a steady constant slight steam leak somewhere from the top of the steam boiler that couldn't be seen by the naked eye. I turned the machine off to unscrew the top and take a look, but couldn't find anything.I lowered the PID temp back to 255 from 261 where I had bumped it. It's weird, I've been able to have it at 261 for a long time before and not experience any problems.
I refilled the reservoir and turned it back on, and didn't hear the same steam leak, so I left it and went to bed. When I got up the next morning the machine was beeping, and the reservoir was completely empty.
Could this be a similar failure as described above? I was afraid to start torquing down copper nuts and washers blindly not knowing what I was doing.
Oddly, this happened 2 days ago, but now it held water perfectly fine all night last night with no noise or steam leak or any other problem this morning.
- Bob_McBob
If you want to find out where an invisible steam leak is coming from, use a little hand mirror or other polished surface. Move it around until it fogs up.
Chris
- TomC
Good tip. I was thinking about using some soapy water sprayed on with a litte bottle for ironing shirts, but thought I'd check here first.
Tom, i tried the soapy water, actually gas leak detector, and the surfaces were all too hot to see any bubbles, the liquid evaporated off too quickly.
I thought the leak was coming from 3 different fittings, which i tightened down before i finally realized it was the safety valve.
