Also interested in knowing what maintenance/tweaks might be worthwhile to do while I have it open. The new pump (Ulka, replacing C.E.M.E.) is just a year or so old, or I'd be doing that. I've heard there are replacement thermostats to help with the deadband? Not really interested in undertaking a PID, though I might be convinced otherwise. Descale (it is solution descaled once in a while...anything easier with it apart?). Gasket replacement (no leaks currently)? Anything?
Any assistance appreciated!
Here's what I know:
Both thermic fuses (that I am aware of) still have continuity. One is just a length of low-temp solder, the other is a real thermostat (no reset button). I don't know if these are brew/steam, or if the wire one is a safety and there is a third elsewhere. They are both located atop the boiler. The plastic connector covers on the non-wire one were black and melted looking.
Heater coil shows ~8 ohms resistance across the terminals.
No heat in either brew or steam mode, and I'm pretty sure that the 'heater on' indicator light is not lit when in brew mode but does come on when steam is engaged.
Here's a pic of the top of the boiler, fuses dead center. Red cloth looking insulation covers the 'solder' fuse, brown dealie right next to it is the one with the cooked terminal covers (which cracked away when I removed the connectors):
