Isomac Tea Troubleshooting
Peli
#1: Post by Peli »
Hey guys,
I have a first generation Isomac Tea that until recently has performed flawlessly. What's the problem? After idling for a while, the brew group seems to dry out. After activating the pump, the machine takes 10-15 seconds for water to appear, and once it does it's barely a trickle. It's also superheated, and at a much lower flow rate than it should be. With a blind filter in place, the Tea takes over 30 seconds to ramp up fully.
What's the problem here? What can I do to troubleshoot the problem and perhaps fix it myself?
~Lowly Barista at Joe Van Gogh's of North Carolina~
erics
Supporter ★
#2: Post by erics »
Replace your brew valve using the instructions found here:
http://www.espressomyespresso.com/HowToE61overhaul.html . The top half of the Isomac group can be disassembled using the guide here: Checking an E61 Espresso Machine for Scale .
The other two valves in the E-61 grouphead will benefit from replacement also in addition to other wear items in the group assembly.
Skål,
Eric S.
http://users.rcn.com/erics/
E-mail: erics at rcn dot com
Peli (original poster)
#3: Post by Peli (original poster) »
Thanks for the reply!
Are the symptoms those of scale buildup or of wear to the valves? I suppose that I'll disassemble the group and try to see for myself.
erics
Supporter ★
#4: Post by erics »
Don't forget the camera so that others might benefit.
Skål,
Eric S.
#5: Post by Peli (original poster) »
I'll have to wait until I get the proper wrenches to perform the disassembly.
