by lfranchi on Thu Feb 11, 2010 12:57 pm
Well, I just replaced the thermal fuse, and covered up the terminals (with electrical tape, my local hardware store didn't have any shrink-wrap tubing...). The continuity across the new fuse was 0, so I think it is ok?
Anyway, I hooked the machine up, dropped the tubes in some water, held down the water-check button, and turned it on. The pump didn't engage immediately, like it used to. In fact, nothing much seemed to be happening. But the heater was slowly working, I think. However, after maybe 25 seconds I felt that something was wrong, so turned it back off.
After unplugging it, and poking around, the thermal fuse leads were *hot*---something that doesn't seem right. Even after 25sec of usage, the leads were quite warm/hot to the touch. Is that normal?
