Isomac Tea - not heating up after descaling
peter75
#1: Post by peter75 »
Hi,
Basically I have the identical problem as described here: Isomac Tea not building up pressure/heating after boiler descale
i.e. my Tea will not heat up nor build any pressure after descaling. I have descaled many times before and never had a problem. The problem occurred after I drained the boiler to remove the acid water.
Now once I turn the machine on, it will just switch the on/off light on and heating light (RED) on and never heat up or build any pressure. The pump however works and pumps water ok.
I checked the thermal fuse, but it seems to be ok (I measured a reasonable resistance value), there is 230V on the heating element, but its resistance is infinite. Hence I suspect that the heating element is gone. Am I right ? or my problem is somewhere else?
Cheers,
/Peter
peter75 (original poster)
#2: Post by peter75 (original poster) »
Really nobody can tell me how to find out that the heating element is burnt ?
Advertisement
erics
Supporter ★
#3: Post by erics »
You suspected correctly.
Skål,
Eric S.
http://users.rcn.com/erics/
E-mail: erics at rcn dot com
#4: Post by peter75 (original poster) »
Thanks Eric for the confirmation.
