by larsschwarz on Thu Jun 16, 2011 2:30 pm
Hi all,
i, well actually my wife, just descaled the boiler of our Isomac Tea. When she flushed the boiler to get rid of the citric acid left the machine starting pumping water again and she closed the valve. Like 30 minutes later when i checked the machine i noticed that the pressure gauge did not went to its regular "i'm ready" position.
I turned off the machine, waited till it cooled down a little bit and turned it on again... no pumping, not a single sound (sound in terms of pumping or heating).
My best guess is that closing the valve in the wrong moment caused some kind of vacuum somewhere?
I remember i already had a similar problem when i was descaling the boiler some months ago, but after some on/offs and waiting for a day everything worked fine again.
I there anything i'm missing related to descaling the machine? And is there anyway to fix this vacuum (if it is something like this) like by opening all valves before turning the machine on or something?
Thanks, best: Lars
edit: i just removed the green cable from the control box (the one that connects to the boiler). turning the machine on then starts the pump as regular. No idea what is it useful for, but i've read it on some thread here. The security valve does not move (which is regular behaviour i assume?). The vacuum breaker valve seems normal (i can lift it)...
