Ok i got a great deal on a three group Dalla Corte Evolution...independent brew boilers, independent grouphead temp through serial connection to usb, temp stable,....couldn't pass it up. They guy said you could hook it up to a stove 220v if i needed to for testing in my place before i move it to its permanent home, but when i look at the info under the drain it says "volt 400 3n" im guessing that means its 400v 3 phase, which i dont have..but the guy said it would work on 220, so i took the "brain" box lid off and took pics of parts to post here...has the machine been re-wired for 220v?
first a pic of the machine
pic of the electronics.
closeup of white box in middle right
side of the white box
side of coil
main switch
here is the end of the power cable.. note how it came with the two black wires wrapped together
