another_jim wrote:Vibe pump volume is not very diagnostic.
Hey Jim, good to hear from you again. Another symptom: if I use the same grind and dose that yield 2 oz in 25 seconds on my Gaggia, then it takes at least 20 seconds for the first drop to appear on the Bric. I need to read up on how to conduct a pressure test and I'll probably need a pressure gauge.
erics wrote:When you hold the mushroom up to light, you should see 5 holes - one is the gicleur and the other four feed the gicleur water. What does the bottom of the brew valve look like?
Eric, the 5 holes look totally clean to me. I assume the bottom of the brew valve is what I see when I look down into the space that the mushroom usually occupies. In that case, I see a clean piece of brass with a unclogged hole in the middle.
I will provide pump information and pics a little later. Thanks for the help so far guys.
