buzzmccowan wrote:Hi everyone, my first post here at HB (many posts on CG). I just received a brand new Vibiemme Super. I started setting it up after 1st Line has already closed. Here's a couple of the things going on. I checked my OPV setting via a blind basket. The tiniest adjustments made huge differences from 6 bar to 14 (this is after the preinfusion stage). I finally landed as close to 9.75 or 10 as I could. However, pulling multiple tests in a row seem to have some fluctuations. I am wondering if I have a sticky OPV.
First, don't panic. As others have stated, Jim is very busy but should be back at the shop early next week. if there is a problem he will take care of it.
Fluctuations on the brew pressure gage should only be taken as an indication of a problem if they are seen while using the blind filter. Changes from shot to shot during pulls can be caused by grind, tamp, distribution, etc.
If blind filter tests do reveal fluctuations from one test to the next, and you suspect the OPV. You can flush the valve out by unscrewing the adjustment screw of the OPV a few turns and running the brew function with the blind filter in place. This should push through a lot of water.
If that does not work, the valve can be partially disassembled. Unplug the machine and allow the machine to cool off and access the OPV. Removing the inner divider panel is also a good idea. Put a towel under the OPV and unscrew the adjustment screw and remove it. Clean the piston and spring with a lint-free rag. Look into the bore with a strong light and look for foreign matter or bits of whatever. Examine the piston as well. If you suspect that there is something in there, plug the machine in, install the blind filter, and turn the power switch to "I," wrap the towel around the OPV, and turn on the brew switch momentarily. Be extremely careful because water will GUSH through the OPV. This should clear any foreign matter. Turn the machine off, unplug it, and reassemble.
buzzmccowan wrote: My boiler pressure gauge read about .35 bar after a long warm up so I proceeded to adjust the pressurestat. I made numerous adjustments and nothing changed on the needle. Finally I made such a big adjustment that the boiler pressure relief valve started hissing and made a pop. The temperatures I am getting seem to be low as well. Out of the hot water wand I get 202-204F water measured in a Pavina glass with a K thermocouple. Returning it would be a real drag.
I have not checked my hot water in that way, but it sounds like the gage is bad. The temp of your hot water seems about correct- at least to say, close enough to verify that the water in the boiler is very close to where it should be and that the pressure in there is close to ideal. Closer than the gage indicates. Worst case, Jim can send you a new gage. A lot easier than spending the $$$ to ship it back!
