Introducing the new La Marzocco GS3 MP - Page 3
- Peppersass
- Supporter ❤
I agree that LM USA is terrific. But perhaps you haven't done business with Chris Coffee. Their support is top-notch.Capitol wrote:One final thing I'll have to say in favor of LM if you're thinking about pulling the trigger on one... I bought my GS/3 direct from LM USA and their customer service is second to none. I haven't received as good of support from ANY other vendor I've ever dealt with.
I agree with the customer support! VERY responsive and helpful!Capitol wrote: As to being more precise, I haven't used this new conical valve yet, so I couldn't say, however... I can consistently and easily hit 0-9 bars and anywhere in between with my existing Strada mod. It took about a month of playing with before I got good at it, and it still requires me to focus when I'm pulling a shot. From what I've been told by LM, this new conical valve is a lot less sensitive. There's probably a quicker learning curve associated with that, but essentially the same functionality.
As for the Strada mod, from what I recall in reading on this, the range from where you can adjust the pressure is very little, which in turn would make it more sensitive. Maybe the conical gives a wider area for adjustment making it less sensitive?
- shawndo
Yes, this is exactly what it does and my opinion is that they are just patching what it should of done in the first place. They should give retrofit kits for Strada MP (and Shot Brewers) for free!YseanY wrote:Maybe the conical gives a wider area for adjustment making it less sensitive?
Darmok and Jalad at Tanagra
always the same question from me, if this is plumbed, with the better control, do people think youll be able to make those super long preinfused slayer shots, or do you need the "flow profiling" instead of the "pressure profiling"
- shawndo
you could do this with the old and new versions. The problem is that regulating the flowrate of the preinfusion is manual, as described above.
Where a slayer has 2 waterflow paths. one is restricted by an adjustable needle valve (that is not adjusted during a shot) and another is "unrestricted"
Then the paddle switches between the 2 paths to enable/disable the special preinfusion flow rate
LM MP has a manual (now conical) valve that is opening and closing and can achieve both of those flow rates and everything in between and more.
With the new model, it should be easier to "graduate" the paddle by measuring and putting a little sticker on the group head that indicates "This position is 50 g/min". Then you can move the paddle to that position at the beginning of a shot, wait some amount of time, then go to full to simulate the slayer preinfusion.
Also, it doesnt need to be plumbed for this anymore according to the press release.
just curious, if you move the paddle the smallest amount to start the extraction, what kind of flow rate (grams per second) would it have?
- shawndo
it goes from 0 to full speed (regulated by whatever gicleur you have)
I can get it to produce a few drops per second.
Quick video to demonstrate.
super helpful explanation, so when you move the slayer paddle past the preinfusion position (where the flow rate is fixed by the needle valve adjustment) aren't all the other adjustments manual as well
it seems in principle that if you correctly layout your start points, you can get to the same place as you might with the slayer or the strada mp
whats the size of the gicleur that comes in the gs3 these days, is that what you have in your machine or something smallershawndo wrote:it goes from 0 to full speed (regulated by whatever gicleur you have)
