mitch236 wrote:That's what makes advanced machines like the GS/3 so stable.
When I think of temperature stable, I think of repeatability. That is, does it produce the same brew temperature profile each time. When double boiler owners/manufacturers think of temperature stable, they think that it's repeatable
and the brew temperature profile is flat. It's a minor point, but I hasten to point out that we haven't reached consensus that flat = better (though few would argue against repeatable = better).
Back to the OP, I believe the BZ10 is similar to the BZ07, which I recently reviewed (i.e., heat exchanger with actively heated grouphead). It's a "dragon type" HX, i.e., it has a very short thermal memory and the flush is basically the same every time, though you can adjust the brew temperature
slightly on the fly by under or over flushing the group. To make life less complicated, I recommend refilling the reservoir with room temperature water since the HX inlet water temperature does impact the resultant brew temperature. I keep a jug of water that was filled the night before for that purpose.
