ronace wrote:OK, but if the thermocouple is inside the boiler, as opposed to the entrance to the group, wouldn't this introduce excessive lag time between the brewing temperature water and the PID?
Ron
A PID temperature controller, or any controller for that matter, is not going to work well if what it is controlling is far removed from what it is measuring. The "what" it is controlling is of course the boiler element.
There are both practical and safety concerns. Presumably, the group is going to heat up with a significant lag as the boiler heats up. This means that any simple controller is going to continue "telling" the boiler element to heat up the boiler water, when in fact the boiler water is already hot "enough," and what is really needed is more
time for the heat to conduct and convect towards the group. The result will be huge overshoot as the boiler heats up and needless oscillation in boiler temperatures before the boiler temperature stabilizes; this assumes that in the process you don't blow the safety valve, which is surely going to be unpleasant. Even after the boiler temperature stabilizes, how such a system (with a remote probe controlling the boiler element) would function is unknown and would vary by machine.
PIDing a boiler is a relatively simple procedure that eliminates or reduces the hysteresis in temperatures that a boiler would otherwise have with a p-stat. There is considerable experience with this approach, both in consumer and professional espresso, and also in industry where PID controllers are most often used. You can take advantage of this experience and know, in advance, that it is going to work out, as you are not asking the system to do anything other than refine the functionality of what is already in there (a pressurestat, presumably).
I'm not saying that a more complicated type of controller, or a controller with more than one thermocouple couldn't solve this problem (and in the process end up with better and finer temperature control), however in this case we are talking about a much more complex system than what you will get with a single TC and an off the shelf one channel PID.
As an aside, I have thought about the possibility of getting longer ensheathed TC probes for my Cimbali Juniors, in order to get them as close as possible to the actual heat exchangers contained in the boiler. If I ever test that, the idea would be that the system would become more responsive since it would (by simple positioning) be effected somewhat more by what is going on in the HX while still being sensitive to boiler temperature. Exactly how this would pan out in real life I don't know, but it suggests one way of biasing the system a bit towards the actual brew water temperature while still (hopefully) retaining a safety margin. I am however finding that my current system allows quite a bit of accuracy and reproducibility of shot temperatures, so any additional improvement would be small and probably not worth the effort involved.
ken
