Here's a pic:
Here is a pic of a familiar touch pad:
Here it is from the back:
The machine works great in every regard besides the fact that when I press the continuous pour button, the pump may only engage for a second or three or not at all. I may press it a few more subsequent times and I may get three to five to one to zero seconds before the pump shuts down again. Other times it may run continuously. This misery also affects the dosed buttons. The touch pad's preset times are controlled by tiny screws on the back of the pad.
I've tried in vain to adjust these to last my desired duration. I have to wonder if there is a failing electrical part or if I'm not using the force. I have no user manual for the unit, so I don't know exactly what I'm doing when it comes to programming.
Two other factors that you should know:
- I'm running water to the Century from my kitchen sink line, via a 3/8 line for about 20 feet. I have soft water in my area. I would imagine the water pressure is fine, but you may know better.
- The Century is attached to a timer. I have no reason to think that the tank is partly empty when the unit receives electricity in the AM, but you may know better.
Could this be a bad control unit? Bad touch pad? Bad water inlet valve? Bad water pressure? Could it be related to the timer?
Things to note about the machine:
I have no idea how long the unit sat and whether water was in the unit at the time. I plan on descaling it soon. I found some brown sludge in the water faucet, making me think it needs a round or two. Also, I'll backflush it soon. I don't think these things have to do with the problem, but are worth mentioning.
Many many thanks for any help you can provide!
