HB wrote:Steve and I discussed this point after reading How to Preinfuse; Extraction Pressure Redux; we wanted to see how a lever's puck saturation compared to your results. Problem is, we haven't figured out how to promptly remove the portafilter after preinfusion without splattering everything within a 10 foot radius with wet coffee grinds. Then there's the question of how intact the puck would be after such a sneeze.
Forgive me if I am misunderstanding this or it was already settled elsewhere. But it seems like a La Peppina could yield one answer your question. As you know preinfusion on Peppina is achieved near the bottom of the lever's arc, with a pumping motion. The meeting of water and puck can be sensed by both sound and feel. As per this site, proper Peppina technique involves waiting for that meeting, then taking the lever all the way down to the bottom, waiting for a 5 second preinfusion, and then allowing the lever to rise.
When the lever is at the bottom of the arc, it seems that there is little to no pressure on the puck, and PF can be removed without a sneeze. That's always how I remove my Peppina portafilter after a shot, tug the lever down (while holding the base), twist off PF, and take it to the sink.
I only forgot to take down the lever once...
~tMb
