It might also be the time that has elapsed since the shower screen and gasket have been cleaned/renewed.
As shown in the pic below, the water must also pass through the dispersion screw and then heads straight for the shower screen. But what you will see when you remove your shower screen is that the water exiting the dispersion screw hits a "brick wall" which is part of the screen and then gets dispersed around that "wall".
The flow is a little over 7 ml/sec and currently forms a single solid stream on my Anita. Of course, that was before I just removed the shower screen and decided it "needed a little cleaning". I will edit this post after cleaning and reinstalling but, if I remember correctly, a clean screen will result in a nice shower head effect.
edit - post cleaning - two small streams and three or four even smaller ones.
