skyryders90 wrote:
Hmm ... care to share some more details and perhaps some photos?
I will post as soon as I take some photos this week.
remember; the brewtus is a dual boiler setup, so I use the system to control a circ pump in the thermosyphon loop to bring the group up to a temp much closer to the boiler temp. when I need to drop a degree or two I use the cooling loop of the control to reverse flow on the thermosyphon to drop group temp using the relatively cooler water from the bottom of the boiler. there is not a lot of capacity to really "cool" the group but to drop a degree is not a big issue. the "cooling" feature is more to give me a bit more agility with adjustments and was never intended as anything other than "I could do it ...so why not".
Sean
