by JmanEspresso on Fri Jun 05, 2009 7:21 pm
What was said about certain coffees liking much different temps, is where the DB shines, I THINK.
I have a HX, setup with Erics grouphead Therm. With that, it is definatly easiER to hit "low" temps and "high" temps, but, as Jon said.. Hitting the exact temperature you want is no easy feat, even with the grouphead therm.
Most, if not all, HX machines, whether it be the smaller Quickmill/Vibiemme etc, or the larger Elektra/La Cimbali HX's, are all dependent on the Pressure-stat.. Which controls boiler temps. At any given setting, the machine "wants" to run in a certain temp range. So for pressure-stat setting "x" you can hit shot temps in a certain range, maybe of 4-5 degrees. It IS possible to hit temps higher or lower then the "range", but then you run the risk of the temperature profile becoming wildly distorted, as the machine doesnt "want" to pull shots at that temp. IE: Yes, you can just flush a WHOLE LOT of water, have a short rebound, and pull the shot, but the temperature isnt going to be nearly as stable, the grouphead can be too cold/too hot, the HX water can be too cold from the tank, and a whole mess of things that Im not qualified to truly discuss because of knowledge, or lack thereof, can happen.
BottomLine: The pressure-stat setting of an HX machine determines you're "range" of temperatures that you can easily and consistently hit. Going much higher, or much lower, with any consistency/repeatability, would really require a pressure-stat change.. And everyone knows thats not something to do multiple times a week.
And this is why, to me, Dual-Boilers really shine. **Pretty much all the DB's that are popular on the market today have the BREW boiler PID'd. Some have the steam boiler PID'd as well**. That means, NO Pressure Stat. The temp you set in the boiler, is the temp you want to pull your shots at. No "flushing methods" are required, other then a quick, say 2-4oz flush after a long idle to bring the grouphead to temp. Changing temps also does not require long flushes either.. Just plug in the temp you want on the PID controller, wait roughly 5mins+/-, and you're ready to go. Need to change it again? Plug it in, wait 5mins+/- Pull/taste/evaluate.
Now, this is just my personal opinion, but I really think that in the next few years, double boilers are going to become the standard in the "pro-sumer" and "semi-commerical" market. They are more or less standard in a commercial cafe setting.. Yes, lots of places still use HX systems with great success,, But I think we could all agree that the margin of error, and amount of training goes down, while repeatability and consistency go up. In the home setting, DB's translate to less sink shots because of temperature.. Allowing us to somewhat eliminate one variable from the equation.. which is always nice.
In the "for what its worth" area, Ive owned my HX for roughly four months..ish. I do really like my machine, but I already have passed the thinking stage, and am currently on the researching/shopping/saving stage of upgrading to PID'd Dual Boiler machine.
**Not ALL Dual Boilers are PID'd. The new VBM Junior DB isnt PID'd
