by spiffdude on Mon Jan 09, 2012 8:49 pm
In my experience, running the steam will rarely cause the autofill to kick in. It must have been on the verge of turning on prior to you starting the steam.
Try this: flush a few ounces from the hot water spout to force the autofill to kick in. Let the pressure come back up and then steam. See how much you need to purge to get dry steam. It's different from machine to machine and indeed does have to do with your probe's adjustment.
You cannot hurt anything by letting the steam run for a while. The steam intake inside the boiler is above the water line so you can't drain the boiler and expose the element that way.
You said your machine is new so it's probably not scale on the probe. Could be it was not adjusted properly at the factory, i can't help you since i do not own that machine. You can try contacting the manufacturer to get data on the proper adjustment. Be warned, fooling around with the water probe may void your warranty and you could possibly burn out your element.
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
