How To Install "Bestcup" water filter in Andreja Premium
Postby jdonen on Sat Feb 13, 2010 10:57 am
Does anyone know how to install the bestcup water filter in the Andreja Premium water tank. The system comes with one tube but no specific instructions on how to install. I find the instruction booklet impenetrable. Thanks for your help. Joshua Donen
jdonen
Postby HB on Sat Feb 13, 2010 12:02 pm
Judging from the photo, I assume the intake line from the Andreja attaches to the available barbed fitting and the filter's line goes into the tank:
Photo courtesy of Chris' Coffee
Note that there are two lines for your espresso machine; the one is an intake, the other exhausts water from the over-pressure valve (OPV). Usually the OPV tube has a V slit, but if you're uncertain, run the pump with a blind basket in the portafilter. All the water drawn by the inlet line will exit from the OPV line (for more details, see adjusting brew pressure / OPVs explained).
Postby HB on Sat Feb 13, 2010 12:16 pm
For the benefit of those reading along, Joshua sent me the scanned instructions:
I see why you were confused; the install instructions above don't match your machine. Based on the photo, I believe my post above is correct. Check if there's a waterflow direction indicator on the filter or its adapter.
Postby jdonen on Sun Feb 14, 2010 12:46 pm
I can't thank you enough for your thorough response.
jdonen
Return to Espresso Machines
