by dgw on Sat Nov 15, 2008 6:03 pm
Thanks, Dan. My gauge pressure went over 1.5 bar and the heating element did not shut off, causing the overpressure valve to release. I assume the pressurestat malfunctioned, either electrically or from scale clogging the line from the boiler. This has happened a few times over the past year, but shutting it down to cool had solved the problem up until today. I did a quick descale similar to the method described in the link you posted and, so far, it has been stopping at 1.5 bar, but when I have the time, I'll dive into the E-61 to clean it up also (although that's obviously not causing the pressure problem).
David
