by shadowfax on Mon Jan 11, 2010 11:25 pm
Scottie,
I don't know about oxidation. I'd think the most likely candidate would be some type of organic growth, particularly given how easy it was to take off. I've read warnings on these things that they're prone to that kind of thing if you filter out the chlorine in tap water upstream of the softener (e.g., with a carbon filter).
I'd think bleaching it (with an extremely mild solution) and flushing it thoroughly might be a good idea in any case, though you might want to ask some softening resin bead experts before doing that. If it proves not to work (I assume you have hardness test equipment), it's probably cheapest to just buy a new, smaller softener.
I think you can probably recharge the resin without any water pressure, but I doubt you'll be able to flush it sufficiently without hooking it up to the water line.
Nicholas Lundgaard
