by cgfan on Thu Mar 10, 2011 12:56 pm
Dana,
Interesting numbers... In line with mine, though reflective of a much greater per day on-time than in my setup.
My numbers were an attempt to gauge how much various items in my coffee hobby were costing me relative to other often-used items around the house. Because of this I did not track the total "on time", that is when the power switch was on and not when the boilers turn on, of my equipment. (Perhaps I should have, as that would allow us to compare relative machine performance...) I just measured the total power consumption (kWH) over a long period of time, ~2 months, to average out varying usage patterns and computed the equivalent power (W) over the total measurement period rather than just the actual "on time".
So because of that any differences between our numbers has to do with both machine differences as well as different usage (on time) patterns. In a sense my post was about how much of our total energy we end up consuming in our hobby based upon equipment characteristics and our usage patterns, particularly when measured against always-on equipment around the house, such as one's refrigerator.
I'm still surprised that my momentarily-on Brewtus takes nearly a third of the power than my always-on 5+ years old refrigerator, (no specific fault to the Brewtus, mind you, which I just love!), and even more so that my always-on hot water dispenser consumes more than half!
Regarding the on time, I was estimating the on time (per day) during the week as well as on weekends. I probably could have said that better. As to power-factor it's probably not too important with respect to coffee equipment (where most of the power consumption comes from running heating coils vs. pumps), but a measurement that's not power-factor corrected would be an "apparent power" measurement as opposed to a "real power" measurement, the latter of which is what we pay for to our utility.
Basically some measurement devices can be thrown off if the equipment being measured uses current to temporarily store energy (usually in a coil or capacitor) only to give the energy back. This back and forth increases the amount of instantaneous current drawn but actually does not do any useful work and hence is neither charged by the utility nor should be measured when auditing equipment. The "Kill-a-Watt" does measure true power (W or kW), but also measures apparent power via its "VA or kVA" measurement.
