How much pressure can an HX steam boiler hold?
Postby frankmoss on Wed Sep 08, 2010 8:20 pm
Maybe this is crazy but I've been thinking about making a DB machine. Could I use an HX boiler as the brew boiler? Mainly, can it hold 9 bars of pressure? I know the HX tube can but I don't know about the rest of the boiler. Seems like it should be able to since it's much thicker than the pipes that hold 9 bars.
frankmoss
Postby HB on Wed Sep 08, 2010 8:32 pm
IIRC, the boilers I've seen have a steam pressure release valve that opens around 1.6 bar and are factory tested around 2.0 bar. I have no idea if they could withstand 9 bar, but it's reasonable to assume they were not constructed with that usage in mind. :shock:
Postby frankmoss on Thu Sep 09, 2010 2:37 am
Hmmm. I could switch out the safety valve if I knew that the boiler could hold the pressure. Anyone tried this?
frankmoss
Postby Psyd on Thu Sep 09, 2010 2:56 am
frankmoss wrote:Hmmm. I could switch out the safety valve if I knew that the boiler could hold the pressure. Anyone tried this?
Nah, most of us use the pump or the lever to generate the 9 bar of pressure. Raising the temperature of the water til it reached 9 Bar would put it at, oh, say 350 degrees F?
Most DB's have the brew boiler at a lower temp (pressure) than the steam boiler.
Or I'm missing something really important in the question?
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby frankmoss on Thu Sep 09, 2010 3:21 am
Psyd wrote:Nah, most of us use the pump or the lever to generate the 9 bar of pressure. Raising the temperature of the water til it reached 9 Bar would put it at, oh, say 350 degrees F?
I mean just forget the HX part and use the boiler like the brew boiler in a DB. I don't care about steaming. I would remove the vacuum breaker fill the boiler completely full. Basically, could an HX boiler function as a brew boiler?
frankmoss
Postby Psyd on Thu Sep 09, 2010 3:27 am
frankmoss wrote:I mean just forget the HX part and use the boiler like the brew boiler in a DB.
Unless I have this all wrong, the brew boilers in DB's are not pressurised to 9 bar. They are pressurised from .7 to 1.0 Bar and the pump is downstream of the boiler.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby frankmoss on Thu Sep 09, 2010 3:33 am
Psyd wrote:Unless I have this all wrong, the brew boilers in DB's are not pressurised to 9 bar. They are pressurised from .7 to 1.0 Bar and the pump is downstream of the boiler.
I was under the impression that the boiler was pressurized to 9 bar. I don't think the pump can be downstream because pumps cant handle hot water.
frankmoss
Postby erics on Thu Sep 09, 2010 5:15 am
Lots of boilers, both hx and brew, are fabricated from copper tubing and typically have a wall thickness of 3.0 mm or ABOUT 1/8". At least two examples of current DB machines (Expobar Brewtus & Vibiemme) have identical vessels for steam and brew, AFAIK.
The allowable pressure in these would be AROUND 350 psi = ~ 24 bar as per this: http://www.copper.org/applications/plumbing/overview/cu_alloy_tube_pipe.html#prodspecs
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby gyro on Thu Sep 09, 2010 5:42 am
The pump is upstream of the boiler in the cold water. In a saturated group at least, there really is nothing significant (pressure-wise, excluding the influencing effects of glicuers etc) downstream of the brew boiler other than the pf, where pressure is again reduced to atmospheric.
gyro
Postby keepitsimple on Thu Sep 09, 2010 7:22 am
frankmoss wrote:Maybe this is crazy but I've been thinking about making a DB machine. Could I use an HX boiler as the brew boiler? Mainly, can it hold 9 bars of pressure? I know the HX tube can but I don't know about the rest of the boiler. Seems like it should be able to since it's much thicker than the pipes that hold 9 bars.
Hi,
I'm not too sure about boilers from an old hx machine, as they wouldn't necessarily have been fabricated to withstand the pressure. You may well be OK, but a better option would be to get a boiler from a single boiler machine - something like an Isomac Zaffiro or similar. That will have been made for exactly the purpose you want.
keepitsimple
CoffeeCON 2012: It's free to attend. It's free to drink. It's going to be awesome.
Return to Espresso Machines
