Water from brewhead of my Duetto doesn't taste that good. It's not the softener/carbon filters, since output from that tastes great.
I backflush w/ detergent ~every week, and scrub after each shot usually. I took off the screen, cleaned... and running straight from dispersion screw also tastes bad.
So I descaled it 2 nights ago (both boilers) using Urnex Dezcal... 1st time in 2 years of use -- I used 1 packet per 500ml, the commercial strength. After flushing for hours, I see metal particles in water.
Yesterday, I followed Eric's tip
Checking an E61 Espresso Machine for Scale on cleaning the mushroom... (man, it had some nasty scaling and flaking... but got it very clean... and also the chamber).
I was sure that will fix it.... but still after many more complete boiler flushes, I still see some metal flakes, and it tastes metallic.
Espresso is ok, I think even improved a bit after all this. But I wonder if I can get it better. Where are the rest of the flakes coming from? Would another descale help?
....should water out of machine taste as fresh as straight out of the filters? (in my taste tests, i also drain the boiler, and then fill a cup.... so it's fresh, not water that stayed in boiler for a while)
Thanks for any advice!
