Billc wrote:Dave,
I love this topic because you cannot see inside the boiler and most of the laws of thermodynamics are in play.
The auto-fill circuit "typically" is a capacitive sense circuit. Very similar to a touch screen.......
Thanks Bill: I too am fascinated by the thermodynamics of the system (physics major). But my ignorance about electronics is probably obvious.
This is the first time anyone has suggested "capacitance" as the criteria for a fill. That is the sort of detail that could maybe help me figure this out.
Jim Schulman (in a post clarifying his "insanely long water FAQ") discusses the circuit as though it were a simple, binary, "ground or open" situation. His interesting idea of adding a switch to facilitate descaling makes me wonder about the potential to damage the machine with such a switch.
another_jim wrote:.........-- If you plan to descale regularly, attach a 3 position "descaling switch" to the autofill circuit. Cut the wire running from from the brain box to the autofill wand. Attach the wire from the logic box to the middle terminal. Attach the wire to the autofill wand to one of the outer terminals. Attach a wire to ground...
In particular, routing the wire directly to ground would be significantly different from the resistance (or capacitance?) that the wire would see from being connected to ground through the intermediary of water. Could that connection "directly" to ground, rather than "through water to ground" damage something?
My machine seems to run fine with distilled water in the boiler, which would be hard to do with a simple resistance test (right?). I wonder about the details of the circuit, and if it could tolerate the change to a direct connection to ground.
This is way beyond my ability to evaluate, so I was hoping someone might allay (or confirm) my fears, because I think the switch would be a nice addition to my machine.
It would be very cool to be able to throw the switch one way to "lock out" the autofill during brewing or steaming, and to be able to throw it the other way to "force" fill when descaling, to get the boiler completely full of descaler. It would also be cool when descaling just the HX, because you could lock the autofill out while the hose was in the descaling solution, to keep it out of the boiler.
