Nickel wrote:I meant how do you physically lubricate the lever.
Take it apart, starting with the screw on the end to get the handle off, then the next fitting, until you can pull the lever out. It has an eccentric cam on the end that depresses two little pegs inside the group, one above and one below. The little pegs are what need the lube. Use food grade lube, I got mine from WLL but there are other sources, and then reassemble. Works like a charm. A small amount of lube will do, keep in mind that whatever you use will wind up in your shots. I used WD-40 the first time but it gave my shots an off taste for a while.
Second time I really gooped it up with the food grade lube and I could see an oil slick on my shots for a week or so (but no off taste).
