How do you descale a non-reservoir machine, ie. Vetrano? - Page 2
Postby eastpresso on Tue Aug 19, 2008 6:05 pm
You don't need a tee. Just use the flojet with a different jug with descaling solution only?
FWIW a tee after the flojet would not make much sense? Unless you did not need it to provide positive pressure to the machine in the first place..seems some people are running the Vetrano without flojet.
Some more info here:
Water, Scaling and Descaling with HX machines?
Bernhard
eastpresso
Postby MDL on Tue Aug 19, 2008 7:46 pm
I thought that one issue with the rotary pump machines like the Vetrano and the Vivaldi II is that the pumps don't suck from a reservoir (hence the need for the flojet systems). I have a Vivaldi and you can pour a descaling solution into the steam boiler from the top if you remove one of the fittings. Since the steam boiler is the only one that ever boils it should be the main place where any scale may develop.
Clearly my comments are not completely appropriate to a Vetrano, or other HX single boiler machine.
Mark
MDL
Postby JohnB. on Tue Aug 19, 2008 9:11 pm
The nice thing about the Vivaldi is that the boilers come apart easily so there is no need to use an acid when descaling. The heating elements are attached to the covers & both covers are easy to remove. I had both opened when I was waiting for my board to come back from the P/I upgrade. The brew boiler was clean but the steam boiler element had a build up. I wiped out the inside of the boiler & cleaned the scale off the element with glass beads.
http://www.s1cafe.com/phpBB3/viewtopic.php?f=26&t=872
LMWDP 267
JohnB.
Postby dgunter on Sun Aug 24, 2008 12:44 pm
@ eastpresso I didn't think that a T would be of much use after the flojet either, but I wasn't sure if you could get away with just using the machine pump for a short time. Thanks for the response! Let's see if I can do this without hurting myself.
dgunter
Previous
Return to Espresso Machines
