How do I remove noisy OPV from Quickmill Anita?
Postby rferoni on Sat Mar 06, 2010 10:17 am
I want to remove the OPV from Anita and see if it's scaled at all. I've been getting that high squealing sound. Annoying at 4:30am when everyone is asleep. I did adjust the OPV awhile back and I know some have just adjusted it a few times and the squealing sound went away. Looks easy enough to remove and inspect though so I figure I'll just do that. Just want to make sure I take care and not mess anything up as I don't know if there are any internal parts I can mess up while taking out.
It looks like all I have to do is disconnect the tube and undo the nut above the OPV.
FWIW I just de-scaled Anita and sound did not go away. Also used the search function but found nothing on actual how-to for removing OPV.
Thanks,
Ron
rferoni
Postby TimEggers on Sat Mar 06, 2010 10:39 am
Hello Ron you are correct, removing (at least partially) the OPV is as you describe. As long as you have it apart it may be a good time to replace the rubber OPV seat. It may or may not help with the squeal. Unsure if scale has any effect either. Nonetheless take it apart and have a look.
TimEggers
Postby earlgrey_44 on Sat Mar 06, 2010 10:57 am
I think descaleing procedure might make a difference too - maybe this applies to your situation.
If you run descale solution through the OPV with no backpressure from the grouphead, you don't flush the valve seat completely.
I noticed an OPV squeal from my HX machine appear toward the end of my last descale interval. For my next descale, I included using a blank in my portafilter and running solution with it in place, forcing solution through the open OPV. The noise went away and hasn't returned.
earlgrey_44
Postby rferoni on Sat Mar 06, 2010 11:32 am
Thanks guys for the quick replies. I'll post results after using for a few days or so.
Ron
rferoni
Postby erics on Sat Mar 06, 2010 12:51 pm
Ron -
Order a replacement valve (the small rubber & brass), an additional spare rubber insert, o-ring, & food grade lubricant from Chris' Coffee. Always apply a counter-hold to the valve connections - that little 1/8" tee CAN BE fragile.
The squeal can result from scale buildup and/or a dramatic change in shape of the rubber valve face from contact with the seat. These valves have very little movement (~0.10") and water spray patterns initiate vibrations.
edit - a little better pic and more explanation.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby HB on Sat Mar 06, 2010 2:35 pm
Return to Espresso Machines
