by erics on Sat Apr 14, 2007 5:20 pm
Whoa -
Lets stop for a second. Ideasite has good intent but I don't think its a doable adventure. First off, a 3/8" hole won't quite be large enough for even a 1/8" pipe thread and a 1/4" pipe thread would need something like 17/32" or 9/16". The way, or rather, a way, to seal pipe threads in a situation like this is to use pipe thread nuts which you would obtain from the lamp repair department of the HW store. I know 1/8" pipe thread nuts are available and I suspect 1/4" but I'm not too sure of that one. I would seal these nuts with copper washers and that is a separate adventure all by itself.
But, most important of all is the fact that this section of pipe thread that is either part of the gage or a separate pipe nipple to which you will attach the gage WILL PROTRUDE into the blind basket such that your dispersion screen will be bent out of shape.
If you want to sacrifice a regular basket - maybe that singles basket that's gathering dust in the drawer, then it's a doable idea after you drill the right size hole and epoxy up the remaining area of the basket.
