by Mach on Sun Jan 30, 2011 10:00 pm
I almost never use the water tap on my ECM Giotto, but I want to do a descale and it seems a lot easier to empty the boiler that way. Also I like things to work. Any quick and easy diagnoses? I took as much apart as I could and there doesn't seem to be much scale or other schmutz anywhere I can see. The hot water valve itself feels fine and though it's hard to tell, it looks like the internal parts are working. What I could see of the copper tubing going to the valve also looks fine and seems clear (I took the smallest, most exposed piece off and it runs clear). Everything else seems to be functioning normally. I had a sticky vacuum breaker valve recently, but it cleared up with a quick cleaning. Thanks, as always, for sharing your expertise!
