Dana, cool mod. Thanks for documenting it.
Tonight I was going to see how long it took for the GFI to trip. After preparing a timer I made sure the machine was nice and hot, flicked the steamer switch on and waited... and waited... and waited, then the light went on. I turned the knob and voilà, steam. Why?
Now, I seem to remember reading that it's good to put the steaming wand in a cup of cleaner before turning on the steamer because it will suck the cleaner into the wand. Does this mean that the steamer pulls air in through the wand for making steam? If so, it is possible that a wand that's so gunked with stuff that it won't spray (not even a dribble) might cause some sort of heating or overload when the steamer can't pull air in? Could this cause the GFI to trip? It does seem that the knob and now the steamer all started working simply from removing the crud from inside the wand.
Now to the main problem, the feller standing in front of the machine who aspires to pull good shots. As I noted above, the machine choked. I ground the beans in my Spong at a setting that's pretty fine, but works fine in my moka pot. It might not be ideal for the moka pot from what I'm learning about coffee though. So I may be grinding too fine to make espressos?
I also tamped it good with the built in tamper, so may have over-tamped. I've tamped a few shots with a tamper, but I compensated for the awkardness of pushing up from underneath by placing my hand on top of the machine. I could easily have compressed it too much, though I tried not to be too forceful.
Finally, the OPV: In reading the CG thread Kristi put together the claim is that the machines come with the OPV locked. Since I did get flow from the OPV I'm wondering if it's been adjusted. If so, should I assume it's been adjusted correctly?
With the above considerations, what would be the most logical step in learning to pull a good shot? Am I better off starting with coarser grounds, tamping more lightly or something I haven't considered?
According to Kristi's thread on CG, it looks like there's another filter option too,
found here. If I understand correctly, the bottom can be hole sawed out without compromising the integrity of the portafilter, making a naked portafilter. Is it safe to assume that the same baskets fit this unit?
