I have just recently brought a La Cimbali Junior machine and grinder and to be honest don't know alot about them but do like my coffee. Since plumbing it in I have come across a couple of issues which are causing me to scratch my head way too much and wondering if anyone could help.
Firstly, I machine has a dosing chamber in the back left hand corner if you were looking at the machine front on. In this chamber are differing metal rods, from what I have figured these correspond to the shoot selector that has been made with the right hand selector on the front of the machine. My question is can these be adjusted to change the amount of water that is released? and if so is it just a matter of lifting the rods to the desired level.
Secondly, The water level in sight glass does not appear to get above anything except min level, can this be fill manually or should it just fill to max when ever the machine is fired up. ( Please note that I have not seen a Junior like this one while looking around this or many other sites ). The two switches on the front are : The left one is an on / off switch and the right one is the shoot selector, giving you four selections, the push button in the middle is how you start the extraction process.
Thirdly, Does this machine have a vibe or rotary pump, how can i tell and what difference does it make?
Thanks
Regards
Roy from NZ
