gscace wrote:bobroseman wrote:The Scarce device isn't really required. I have a 5 foot long 36 gauge T junction teflon coated wire which fits neatly over the edge of the PF and into the basket space. For repeatability I suppose that it could be anchored but I haven't bothered.
The only problem with this set up is that you have a PF full of water which is thermodynamically different than one filled mostly with coffee. I have chosen to ignore the difference in my tests. My results on the La Spaziale are very similar to Greg's results on the La Marzocco.
Bob
The test conditions are quite different between the two measurement methods. In your method how is water flow rate controlled? Several years ago, I made a bunch of measurements on Rancilio Silvias using T type thermocouples snaked up through the filter basket with the probe resting on top of the coffee cake. It was a ton of work and couldn't make constant duty cycle measurements. The thermofilter makes it almost trivial.
-Greg
Greg,
In the picture earlier in the thread you will see there is a needle valve which can be adjusted to permit 2 oz of water to flow in 25 seconds. The pressure can then be read.
However when it comes to measuring temperatures, my set up has problems. One is that the placement of the TC can vary and, two, there is no coffee in the basket and so the thermodynamics are wrong. As I stated, I have ignored these things. Your method might eliminate those problems.
When I said that your device wasn't required, I meant in conjnction with mine. I'm sure that your device works quite well as a stand alone.
Still, my curves are remarkably similar to those that you achieved on the La Marzocco, if memory serves.
Bob
