by Randy G. on Tue Dec 27, 2011 12:01 am
I do not know the Expobar Brewtus, but most double boiler machines have two pressure valves. One is the safety valve mounted on the steam boiler. If this one opens you would know it from a violent release of steam and/or hot water which might spray all over the inside of the machine. This would be caused by over pressure (and over temperature) from a faulty pressurestat or from a water level fault causing the boiler to overfill. The other is referred to as the pressure relief valve that regulates the brew pressure at the group when making espresso. It only allows a set maximum pressure to reaching the coffee. if this malfunctions or needs adjusting it can result in too high of a brew pressure or too low. This would bee seen as an excessive flow rate of the extraction, or at the other extreme, no flow at all.
Now, if your machine is PID equipped (red digital display on the front) the brew temperature is electronically controlled.
So, does the machine have good steaming power?
Does it dispense hot water properly?
Is the problem only brew-boiler related?
What does the excess water come out of? (excuse my dangle)
How long has it been in use?
When was the last time it was thoroughly descaled?
What water do you use in it?
How is the water "processed" (softened, filtered, etc.)?
